lift advice
Old Aug 12, 2009 | 06:43 PM
slimblack's Avatar
Default lift advice
so right now i have a stock x 2 door with 305/65/17 M/Ts on pro comp wheels with 4.5 inch backspacing. when these wear out i plan on moving up to 35/12.5/17. my current setup rubs a little so im planning on installing a lift. my question is what lift should i get that will look right with my current setup and also allow me to put 35's on without rub when the time comes. money isnt really a huge factor because i want it done right and ive learned that you usually get what you pay for.
Old Aug 12, 2009 | 07:01 PM
mkjeep's Avatar
PM bigbluejk, he's real happy with the TF 3in
Old Aug 12, 2009 | 07:03 PM
mkjeep's Avatar
Of course if money doesn't matter , get the EVO system and long arms
Old Aug 12, 2009 | 07:52 PM
bigbluejk's Avatar
ya dude, that tera 3" works great. If you have the money go long arm like said above.
Old Aug 12, 2009 | 08:19 PM
slimblack's Avatar
bigblue did you lift kit require any additional parts (trac bars, sway bars, brake lines) or does the teraflex kit come with everything u needed.
Old Aug 12, 2009 | 08:22 PM
09rubicon's Avatar
2.5" will clear 35"s, any more than 3.5" and you may be looking at new driveshafts. See what you like in that range (there are about 20+ kits of varying price and components in that range) and make the decision best for you!
The vid in my sig is my 2dr with the TF 2.5" and 35"s.
Old Aug 12, 2009 | 08:26 PM
bigbluejk's Avatar
I added JKS trackbars front and rear. It comes with front SS brake lines and a rear brake line drop bracket. Now that the tera trackbar is out, I would run it and their axle mounted bracket.
Old Aug 12, 2009 | 08:46 PM
slimblack's Avatar
well that sounds like a good option. have you had any issues with strain on the u joints due to the change in angle on the driveshafts.
