Proper setting for control arms on Teraflex 4" with flex arms
Old Aug 13, 2009 | 09:06 PM
iadventure's Avatar
Default Proper setting for control arms FOUND IT...
FOund it in the write-ups
Old Aug 13, 2009 | 09:11 PM
mkjeep's Avatar
Should be in here
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Aug 13, 2009 | 09:14 PM
iadventure's Avatar
Yeah I just checked there AFTER I posted this. Thanks buddy, I think this will help.
Old Aug 13, 2009 | 09:20 PM
mkjeep's Avatar
Yeah , print that out and bring it outside when you install, it'll make it a whole lot easier.Also, read it about 5 time before you do it.
Old Aug 14, 2009 | 06:08 AM
Ryanclimbs's Avatar
Default Teraflex flex arm installation help
As much as I LOVE Teraflex; their directions SUCK! I was at the Terafalex sponsored JK Event last month and a guy had just put on quick disconnect anti-swaybars inside out because he couldn’t “interpret” the directions and punched a hole through two tires!!! He would have been ok anyways with offset wheels but he had the stock ones on.
When my mechanic was finishing installing my LCG LONG ARM lift kit (ie welding on the control arm mounts) he put a control arm on upside down. I went wheeling and couldn’t believe it and went back and “let him have it” and he proceeded to show me the Teraflex directions that were very misleading!!! It was sooooo bad! I bent my front trackbar because the control arm was WRONG but Teraflex went WAAAAYYYYYY out of their way to make everything right. Other than the directions sucking Teraflex is an unbelievably awesome company!
So good luck!!!!
TERAFLEX often posts revisions on their website. Before you install call them and make sure you have the latest set of directions!
Here are a few links you may want to read:
READ THIS: http://project-jk.com/jeep-jk-write-...s-installation
http://www.*********.com/tech/billav...%20install.pdf
https://www.jk-forum.com/forums/show...aflex+flex+arm
