35s - MTR w/Kevlar vs KM2
FYI - I've had both set-ups on my JK. The MTR is lighter and feels better on & off road. Also, the MTR looks taller and wider than the KM2.
The specs from tire rack say they are both 34.8 and 12.5 wide.
The MTR appears a lot wider than the the KM2 though........
USA
USA
Thank you very much. I was sitting here contimplating between the two as you wrote this. Don't want to weigh the little jeep down to much. Like both of these tires. Haven't had either, been running toyo mt's. Any other info you could add would be great.
This is important to consider. Not only is the lighter weight easier on the axles, and drive lines, but I can actually lift my mounted 37" MT/R Kevlar spare onto my tire carrier without hurting myself. I'm not sure that would be the case with a similarly sized Toyo.
-meljr
-meljr
