Spare tire size
Old Aug 15, 2009 | 05:32 PM
ninjajmoney's Avatar
Default Spare tire size
Can I only use a 305/70/16 for a spare if that is what I am running or can I get something like a 285 and still be ok?
Old Aug 15, 2009 | 09:02 PM
Muffins's Avatar
Especially with 4x4 you should run the same size tire, especially if its for more than a few miles. Plus having all five tires the same looks better
Old Aug 15, 2009 | 09:52 PM
Red Dog's Avatar
If it isn’t the same size I wouldn’t use it. It will end up costing you $$$.
Old Aug 16, 2009 | 09:35 AM
Mark Doiron's Avatar
You will drive your computer bonkers if you throw a different size tire on there. I'm no expert by any means, but it's my understanding that there are wheel sensors on each wheel. They verify that the wheels and some type of motion/G sensors all show the vehicle operating without skidding, slipping or sliding. One wheel rotating at a different rate will throw all of that off. At the very least, you will likely get an ESP light, consequent loss of gas pedal, and computer-controlled braking on one side of the Jeep as you're trying to accelerate. Bottom line: You really need a spare the same size as you're other four tires.
Old Aug 16, 2009 | 12:35 PM
Word
Old Aug 16, 2009 | 01:30 PM
GoodysGotaCuda's Avatar
If you had to, you could manually disable the ESP. The spare tire would have to be on an axle that is open (if you have a rear limited slip), and you cannot use 4x4...
