Budget boost or susp lift?
New jeep owner. I was planning on a 3" teraflex for my 35's. I drove one today at the dealer and it felt very squishy and top heavy. I do NO wheeling and only want the look.
Would I be better off with a budget boost or some other option. Thanks for the help from a non mechanical newbie.
And I agree with the others, a BB should be fine for your use. If you need a little added clearance, you can always trim the flares or throw on a 1" body lift.
https://www.jk-forum.com/forums/modified-jk-tech-2/modified-tech-faq-answers-questions-every-newbie-has-18617/
http://project-jk.com/jeep-jk-write-...-end-alignment
Shocks play a huge role in ride quality. i did a bb with my stock rubicon shocks. it still rides very smooth, however not as smooth as factory since the angles of the arms will change. However this is with any lift. Every different spring, amount of lift, and shock combination will ride differently.
I have found people's view of a "good ride" will vary dramatically. So be careful. ...
If all you are doing is adding some 2" spacers on top of the coils and possibly some shock extensions, your ride quality should be unchanged.
And don't run out and pay for an alignment right away!
Browse through the write-up that was linked earlier. Re-center the steering wheel if needed, maybe toe in the 35's a bit, and you're good to go.
