Spidertrax spacers... Loctite or not?
I would think it would make sense to locktite the spacers on... Suggestions? Blue or Red? Also, I am in the Northeast and see some nasty weather variations...given the hard anodizing of the Sidertrax spacers is there any reason for or against using anti-seize between the spacer and wheel hub to avoid the spacer seizing to the hub?
I certainly dont see where it would hurt anything.
I have the Teraflex steel spacers and used blue locktite on mine. Too many stories about how threads are ruined with the red for me. Plus, I've seen it happen a good bit. If they are installed correctly, the blue will be sufficient. Having said that, I would still recommend following Spidertrax's deestruckshuns. Whatever they say to use....use it. Oh, and if you wanna use something between the hub and spacer, I would recommend red high temp permatex. Totally not necessary, but not a terrible idea.
Have you ever tired to remove them? Assuming you can pre-heat and then break the loctite, I've seen spacers seize to the hub and be near impossible to remove..
Use the Red loctite that the MFG provides.
David
