BFG Mud-Terrain T/A KM2 (LT285/70R17D1) on stock 08 Unlim 4DR bump issue.
Old Aug 19, 2009 | 03:44 PM
mcraigh's Avatar
Default BFG Mud-Terrain T/A KM2 (LT285/70R17D1) on stock 08 Unlim 4DR bump issue.
I installed new Helo 852 black (17x8 5-5) wheels and 33" BFG LT285/70R17D1 tires on my stock 2008 Unlimited 4DR. All is well except sometimes when I hit dips or bumps a little hard (not that hard) my tires seem to rub. I have not found any evidence of where the rub is happening yet (only bumped twice now), but I was wondering if I should be concerned. I really don't want to put a lift on it and that may negatively affect my lifetime bumper-to-bumper and drive train warranties.
Old Aug 19, 2009 | 03:57 PM
nthinuf's Avatar
Swapping bigger tires on had an effect on your warranty. You know you want a lift, go for it!
Are you going straight when you hear it? Turning to only one side of the other? First guess is it's that stupid plastic skid/air dam. Second guess would be the front bumper.
And do you know the backspace on those rims?
Old Aug 19, 2009 | 05:02 PM
mcraigh's Avatar
I was going straight. I will look into the wheel specs. I was told by the assistant manager at discount tire (he made a call to some "expert") that the dealers were putting 33s on their modded wranglers.
Old Aug 20, 2009 | 11:44 AM
mcraigh's Avatar
What are some good (or best) 2" bb lifts out there?
Old Aug 20, 2009 | 01:27 PM
RevyJKU08's Avatar
What was the BackSpacing on the rims??? This could be your issue? I am guessing you have a higher BS and the rim is sitting to close to the suspension components and causing the rubbing issue.
Old Aug 20, 2009 | 07:13 PM
mcraigh's Avatar
I found this information for a similar product, but no luck with the HE852...
Product ID: HE84278050300
Finish: Black Painted Wheels
Product Name: HE842 17x8 5/5
Description: Helo HE842 one-piece black and machined finish aluminum custom wheels with 0mm Offset, and 4.5" Backspace.
Old Aug 23, 2009 | 08:47 AM
RevyJKU08's Avatar
4.5" BS should work...I got the same specs on my Eagle 140 Series 17x8 and 4.5" and I run a 33x12.50R17 Cooper STT when I ran it stock suspension I had no issues with rubbing unless I went off-road when I flexed a little it would rub on the rear stock fender flares. I have no rubbing issues off-road with the 2" RE lift and mono shocks.
Old Aug 23, 2009 | 09:05 AM
dfe's Avatar
dfe
Bit off topic, but since moving from stock to these tyres did it influencing anything, power, fuel etc? I am planning on fitting the exact same size soon.
Have the Zone Offroad 3" lift so not concerned about rubbing issues.
Old Aug 23, 2009 | 10:37 PM
mcraigh's Avatar
Power is degraded a bit (i notice more tac on hills) and a bit less gas mpg. Still worth it!
