1" PA body lift install question
Do you really need to remove the air bag fuse? I dont think other body lift kits require this.
Also why do you have to mess with the steering shaft? I dont think other kits mess with this either.
By the way, i have been looking at the M.O.R.E. install notes and comparing them with the PA instructions.
i did, just cause i was following the intructions, but i've had buddies do them and they didn't do either of those things and it worked out fine, so your good either way i should think!
