Zone 3" coil lift
Old Aug 22, 2009 | 01:46 PM
07crawler's Avatar
Default Zone 3" coil lift
Is anyone running this lift ? The price seems right but wondering how the kit is . Can anyone give me some insight on the pros and cons with this lift? It just seems to cheap ( as in price ) over the teraflex coil lift
Old Aug 22, 2009 | 01:54 PM
STUPIDFACE's Avatar
Its a good starter lift in my opinion. I have it, but am going to get a terra flex long arm pretty soon. It does ride pretty soft and you will probably need an adjustable track bar in the front if you want your wheels centered. All in all, its a good lift. I wheeled it and it performed well.
corey d
Old Aug 23, 2009 | 03:45 AM
abetterview's Avatar
bds makes good lifts but it seems a little small for its price. i think the teraflex 2.5 coil lift is the same size or bigger and a lot cheaper.
Old Aug 23, 2009 | 04:08 AM
JKJosh's Avatar
I had it and had no problems at all. I did add the adj front track bar.
Old Aug 23, 2009 | 06:02 AM
JK-KJ's Avatar
Teraflex is better quality probably, but it is by no means "a lot cheaper"....
Zone 3" Coil kit with shocks, extended sway bar links, bump stops, trackbar bracket
$439.99
Teraflex 2.5" Coil kit with shocks, extended sway bar links, bump stops, trackbar bracket
$679.99 (Northridge price)
Old Aug 23, 2009 | 01:02 PM
my bad i was thinking about bds not zone sorry.
Old Aug 23, 2009 | 01:29 PM
rmdchewie's Avatar
Nice bang for the buck, I run it and am very impressed. The only issue I've run into is the rear shock hitting the trackbar bracket at full stuff. I only netted 2.5 inches but I also have bumpers, tire carrier, onboard air and full belly skids for some extra weight so that probably explains that.
