ignition kill switches
Several thefts of Jeeps reported on TV in the San Diego area. Easy access to the engine compartment apparently makes it easy. Anyone suggest a effective ignition kill switch?
I just use a full battery cut off placed on the negative side of the battery. https://www.summitracing.com/nv/parts/sum-g1432 I have this on my TJ https://www.summitracing.com/nv/part...-12v/overview/
On my manual transmission XJ I had one tied into the clutch disconnect. I'm thinking about tying into the NSS on the JK. A well hidden switch inside the cab someplace might make sense
Ravelco only way to go
Ravelco Anti Theft Device
Not one vehicle ever STOLEN . . .
by defeating a properly installed and utilized Ravelco!
Takes about 10 min to install. Its not a remote start, the remote triggers a relay in the box to connect and disconnect the battery. it also has a hot lead you can use for the radio or an alarm system that is not affected when you shut it off.
Yea sorry not remote start but essentially turn on and off.
I'm making my own circuit breaker/SPOD type device. I am putting in a water proof enclosing, so maybe I can somehow fit this in.
I read the other day that they had busted the San Diego Jeep theft ring that was working out of Mexico.
Feds bust Hooligan motorcycle gang for high-tech auto theft ring | fox5sandiego.com
