ignition kill switches
Old 06-03-2017, 11:35 AM
jkzombiehunter's Avatar
Default ignition kill switches
Several thefts of Jeeps reported on TV in the San Diego area. Easy access to the engine compartment apparently makes it easy. Anyone suggest a effective ignition kill switch?
Old 06-03-2017, 01:12 PM
TheDirtman's Avatar
I just use a full battery cut off placed on the negative side of the battery. https://www.summitracing.com/nv/parts/sum-g1432 I have this on my TJ https://www.summitracing.com/nv/part...-12v/overview/
Old 06-06-2017, 12:36 PM
kejtar's Avatar
On my manual transmission XJ I had one tied into the clutch disconnect. I'm thinking about tying into the NSS on the JK. A well hidden switch inside the cab someplace might make sense
Old 06-06-2017, 12:52 PM
jchappies's Avatar
Ravelco only way to go
Ravelco Anti Theft Device
Not one vehicle ever STOLEN . . .
by defeating a properly installed and utilized Ravelco!
Old 06-13-2017, 09:15 PM
EHarris's Avatar
I went with a bolt hold lock for $50. I want some kind of switch also but I figured maybe just locking the hood was enough to keep them moving on.
Old 06-14-2017, 06:05 AM
jchappies's Avatar
Locking the hood only keeps them from cutting the horn. You really need to stop them from starting it or from getting to the OBDII port
Old 06-18-2017, 06:32 AM
EHarris's Avatar
Woah! I need that for my Baja trips. The second link with the remote starts, how difficult of an install is this? Looks almost too simple?
Old 06-18-2017, 06:43 AM
TheDirtman's Avatar
Takes about 10 min to install. Its not a remote start, the remote triggers a relay in the box to connect and disconnect the battery. it also has a hot lead you can use for the radio or an alarm system that is not affected when you shut it off.
Old 06-18-2017, 08:38 AM
EHarris's Avatar
Yea sorry not remote start but essentially turn on and off.
I'm making my own circuit breaker/SPOD type device. I am putting in a water proof enclosing, so maybe I can somehow fit this in.
Old 06-20-2017, 04:37 AM
Bradlybob's Avatar
I read the other day that they had busted the San Diego Jeep theft ring that was working out of Mexico.
Feds bust Hooligan motorcycle gang for high-tech auto theft ring | fox5sandiego.com
Quick Reply: ignition kill switches
