Dual Battery Box for the JK 3.8L 3.6L 5.7L 6.4L 5.3L 6.2L Any engine.
Old 01-13-2014, 05:52 AM
JSS
Former Vendor
JSS's Avatar
Default Dual Battery Box for the JK 3.8L 3.6L 5.7L 6.4L 5.3L 6.2L Any engine.
Our Battery box will work with any engine (Hemi, LS, 3.8L 3.6L) and it will work with AEV snorkel. This is a complete battery box and you do not need to reuse any of the old box our battery box is complete.
You can use the stock size batteries and they are easy to service.
Name:	Jeep pics 077.jpg
ID:	523284   Click image for larger version
ID:	523285   Click image for larger version
Name:	Battery Box Four Wheel and Offroad 005.jpg
Old 01-13-2014, 05:55 AM
DunnyBunny's Avatar
And the price?
Old 01-13-2014, 06:30 AM
Jeepin' Bear's Avatar
Looks pretty cluttered. Do you have a set of installation pictures that show the process thru completion? What kind of battery voltage management is in place? As previously asked: price?
Thanks.
Old 01-13-2014, 07:45 AM
JSS
Former Vendor
JSS's Avatar
The Battery box sells for $250.00 and we have a Video on our site of the install. Also the pic i have is a HEMI jeep and they get tight on room, so it could look cluttered.
Old 01-13-2014, 07:50 AM
ToolManTimTaylor's Avatar
For the 6.2 does the T.I.P.M get moved forward? On mine the intake occupies the space between the module and rad support and is tight .... Ish
Old 01-13-2014, 09:38 AM
JSS
Former Vendor
JSS's Avatar
The TIPM stays in the same location, has it was in a 3.8L/3.6L. But we moved it up so we could get more room for the wiring, that is why we made a new TIPM mount.
How do you have the engine set up, we have a air cleaner mount also.
Old 01-13-2014, 03:47 PM
4wdave's Avatar
I had to walk outside and look at the space between the side of the Hemi and the present battery installation. It looks like there would not be much space left between the battery box and the side of the engine. I sure am wanting to install dual batteries again and this looks like a viable solution.
Old 01-13-2014, 05:00 PM
Hmmmm we need to catch up. The air cleaner / radiator hose setup is out of whack
Old 01-14-2014, 06:12 AM
Sponsoring Manufacturer
TeraFlex's Avatar
Old 04-13-2014, 07:58 PM
arjeeper's Avatar
Any more pics? Anyone installed this?
Quick Reply: Dual Battery Box for the JK 3.8L 3.6L 5.7L 6.4L 5.3L 6.2L Any engine.
