Poison Spyder Hood Louvers--Now for JK!
#411
simple fix for
eliminating water from dumping in when washing it or heavy rain or when it snows here in the north woods and is parked outside. Works for me anyway ! Some dont mind the water but i did . Just some black vinyl for upholstery and ill get some black waxed rope string. and 4 of these spring fasteners( 4) plastic snap grommets for a tie off. All for about 15.00 bucks / roll it up when not needed .
Just what i did anyway . It just bugs me to watch water rolling into the vents when it can be prevented pretty easy for a few seconds worth of time to toss it over the louver. it falls into place so really you dont have to tie it except if its windy and you leave it. (maybe some stick on magnets would work well too . but ill most likely use tie off
Just easyer when you wash it too . no having to wipe dry all the water on the louver
#412
I'm not baggin on you. You are not the only person that has had that concern, and you have come up with a solution that fits your need, so kudos. But, do yall not clean your engines at all? If so, what's the difference?
#413
A little extra time big pay-off
I just wanted to share an idea I had and the results, well were excellent. First after you make your cut-outs save the metal, second take the extra time and mask off the triangles underneath the hood. Sine you have to spray the edges to protect from rusting use rustolium semi black gloss and paint the triangles black as well as edges. When you install the louvers it will give the hood a very factory look. Then take the cut out pieces and make squares and place them behind the spyders on your bumpers and skid plate if you have them. After you clean the back of bumpers/skid plate use 3M body tape along with 3M adhesive promoter (you will swear they are welded on) This will make the recesses pop. Have black paint an accent color and make those Spyders really stand out. Pretty trick for hardly no money just time.
#414
No one said anything about loosing a engine from having the louver
LOL, how you get the hood lover clean? Granted, I don't have to park outside overnight or during the day when it rains, but still......wash engine all the time with lower pressure water. same thing. Unless you have an exposed air filter, what is the harm here? These have been around for ages. Someone please show me the documented incident where someone lost an engine due to water trickling from a hood louver.
and generally all i need to do with cleaning my engine bay area is wipe it with
lemon pledge or some cleaner product . Its just dusty. Not mud or clay so once or twice a year is all
why do people by car covers or partial covers for their jeep ? To keep some elements out.
I for one am in tall pine trees and the dam pine needles alone is enough reason to have a cover over the louver . They dont just blow away as you drive . You have to pull them out of the slots in the vent some days even worse with a rain and wind and pine needles . This should help with that type of thing (trust me im not anal about my jeep being clean lol) it sees quit a bit of nasty conditions during hunting season too
There are more than just one type of jeepers out here to be quite honest. not every one does rocks or mud And different parts of the country have climate variations my area is logging roads . Not baggin on u (as you put it ) on you either lol
#415
