Poison Spyder Hood Louvers--Now for JK!
Former Member
The Poison Spyder JK Hood Louver helps keep your engine running cool by promoting airflow through the engine compartment. Many factors can contribute to high under-hood temperatures, which can translate to higher engine coolant temperatures and overheating. Headers, slow speeds, flex fans, and the cramped spaces of the engine compartment can all contribute to increased heat and reduced airflow.
This Hood Louver kit frees up airflow through the engine compartment, allowing hot air to escape and cooler air to be drawn in through the radiator, improving cooling of both the engine coolant and under-hood air. Rock-crawlers and slow-moving vehicles are especially susceptible, as slower speeds naturally result in reduced airflow.
In addition to improved cooling performance, Poison Spyder Hood Louvers add great looks to your Jeep! Crafted from thick gauge aluminum sheet, CNC laser-cut and precision die-stamped. Hood Louvers are fairly easy to install but do require some drilling and cutting of your hood. Stainless steel fasteners are supplied. Hood Louvers are available in bare aluminum or powder coated black.
We've had these for TJ's for years, and are finally releasing it for the JK! We'll add more installed photos as we get them, we're just a little light on them at this point since this is a brand new product
Former Member
Here's an interesting look at the packaging process used to protect our aluminum Hood Louver panels during transit. We had to put almost as much R&D into the custom packaging as we did for the part itself!
First the bare or powder coated Hood Louver panel goes into a protective plastic envelope...
Specially made styrofoam box liners protect the Hood Louver during shipping. First the installation guide and cut template go in...
Next the Hood Louver panel is carefully packed into the styrofoam box liner. Hardware kit is taped into place in the corner.
The specially made cover piece holds the Hood Louver panel snugly in place while protecting the raised louvers.
The styrofoam box liner and cover, with Hood Louver panel snugly in place, is inserted into a heavy duty, specially made carton.
Once its sealed up, its ready to ship around the world and safely reach its destination.
Looks good and I am considering this, or at least some louver system, but I think it would look much better if you painted under the louver flat black and not have the paint colour show thru. As my JK is Stone White this would be more an issue than a darker coloured Jeep IMO.
Former Member
Its not just you. Lots of people seem to have that concern. So far we haven't heard of it being a problem for anyone, and there is already an installed base of hundreds of these on TJ's all over the country. Its not like the engine compartment is sealed anyhow. Water can and does get splashed up into there. But the engine itself is well weatherproofed from the factory, so whatever rain water trickles through the louvers doesn't hurt anything. Just make sure that if you do any extra mods under the hood, such as adding wiring for lights and such, that its all weatherproofed with good automotive connectors.
Former Member
looks awesome, 2 big questions. a) cost? and b) any chance of a sneak peak at the install instructions? I love the idea of one of these, as it looks wicked and I like a cooler engine, but cutting the hood always scares me. for some reason. I mean sure, taking the sawsall to the frame was no issue, but that pretty orange hood, I love it so!
Former Member
Yeah some people have a hard time swallowing the cutting of sheetmetal, especially when they're still making payments on it! LOL...anyhow, here's a link to the install template, which has instructions on it.
Former Member
