Vector Offroad's JKE-Dock
Sponsoring Manufacturer
JKE-Dock (JK Wrangler Electronics Dock) $129.99
The Vector Off-Road JKE-Dock installs directly to your 2007-2010 JK Wrangler dash using existing mounting points. It is 100% bolt on, and requires no permanent modification to your Wrangler. JKE-Dock provides a clean solid mounting point for your Cell Phone, GPS, Spot Messenger, Flashlight, CB, CB Microphone, Radar Detector, Ham Radio, etc… The Dock also has an integrated dash top storage tray. The tray is a great place for sunglasses or other small items you would like to keep close at hand.
JKE-Dock works in conjunction with RAM™ Mount accessory brackets and mounting balls. (http://www.ram-mount.com). Start with a 1" diameter RAM™ base with u-bolt(RAM-B-231U) and place it anywhere along the Dock with your favorite RAM™ Mount and Arm.
The JKE-Dock is manufactured in the USA using hi-strength steel tubing and stainless hardware. It comes standard in a durable semi-gloss black powder coat finish.
