Alpha Expedition: HK1 Expedition Tools
Sponsoring Vendor
Alpha Expedition
Alpha Expedition
The HK1 is the world's first and only Hydrokineticly adjusted wrench. 1) It covers 23 standard sizes and any other sizes between ¼ - ¾ inch or 7 - 19mm; 2) It can be easily adjusted by moving its pistons; 3) It can remove damaged nuts and bolts; 4) It can fit into areas where other adjustable wrenches cannot; 5) Its cold forged steel construction makes it one of the strongest and toughest; 6) Its attractive nickel plated finish makes it an ideal gift. For demonstration please visit expeditiontools.com
Now available to be purchased at: ( limited stock)
Alpha Expedition (click)
Looks slick, but 1 question..... How tough is it? A lot of us can torque harder than a standard adjustable can take... Is this any better or worse? Lifetime warranty?
David was kind enough to let me buy one of the first ones he got. Iam a mechanic by trade. I used the shit out of this wrench and all I got to say is wow. It can replace up to 3/4" and 19mm wrenches in the Jeep.
I was a little weary so I abused it at work. It held up never slipped and even worked on rounded nuts and bolt heads. After 2 weeks I retired it to my jeeps tool box.
I recomend buying one of these youll be happy you did.
Good call David and thanks for the new cool tool.
Sponsoring Vendor
Alpha Expedition
Alpha Expedition
Remember every tools has its limitation on what can or can't do or fit. Just like a Swiss knife
Expedition Tool inc Limited Lifetime Warranty & Product Guarantee:
Expedition Tools products carry a LIMTED LIFETIME WARRANTY against defects in materials and workmanship for the product's useful life to the original purchaser. The warranty is not transferable. Expedition Tools does not, however, warranty its products against wear caused by normal use or damages caused by misuse, abuse, failure to perform proper maintenance, deterioration of finish, or for uses which they were not designed. Expedition Tools has no liability for general, incidental, consequential, or indirect damages. Expedition Tools only liability is to repair or replace, at its option, any of its products determined by Expedition Tools to have been defective.
If you feel your product is defective or has a problem please send it to the address below and we will either repair or replace products covered under warranty. Normally, for a nominal fee, we will do the same for products not covered under warranty:
