G2 Axle&Gear Core 44 Rear Housing for tough off-road conditions!
You’ve lifted your 4x4, slapped bigger tires on, loaded your Jeep with all possible mods, but your factory 4x4 axle assemblies don't seem to handle it properly? Than brand-new bolt-on replacement axle assemblies are just what you need and Core 44 Rear SAE Axle Housing by G2 Axle&Gear is one of the best options to consider. This high-pinion housing is designed to reduce driveline angle and protect the driveshaft.
Core 44 axle housings are designed for the ’07-current Jeep JK Wrangler and Wrangler Unlimited. They are engineered to be a direct replacement for the stock JK Dana 30 or JK Dana 44 and will accept stock JK Rubicon Dana 44 gears, axleshafts, and electric Tru-Lok lockers. It features a unique Adjuster Nut System to easily set backlash and carrier pre-load. The Core 44 includes heavy duty 3" x .250" wall tubing to resist impacts even in the most extreme conditions. Its brackets are laser cut and CNC formed from 3/8" steel for added strength, designed for bolt-on installation. Watch this video to find out more about https://www.youtube.com/watch?v=W94xTXqj6To G2 Axle & Gear® - Core 44 Rear SAE Axle Housing https://www.carid.com/images/for-for...xle-jeep-1.jpg https://www.carid.com/images/for-for...xle-jeep-2.jpg https://www.carid.com/images/for-for...xle-jeep-3.jpg https://www.carid.com/images/for-for...xle-jeep-4.jpg Make sure your Jeep can handle the most extreme trail rides with G2 Axle & Gear® - Core 44 Rear SAE Axle Housing! |
I have had my Core 44 front for two years!
It is still working great! |
Starting tomorrow there will be up to a $500 rebate on the G2 axle assemblies. We will post a link once it is available.
