JK Tire Relocation Bracket from A to Z Fabrication Now at Quadratec.com!
Sponsoring Vendor
This new tire adapter from A to Z Fabricaton allows you to put any pattern spare tire to any Jeep vehicle (sans the Full Size Jeeps). It adapts from 5 on 4.5, 5.0 and 5.5 to the same. So you can run new 07 Wrangler JK Rims on your TJ (Using Wheel Adapters) and still be able to use the stock spare tire carrier or vice versa. For those Wranglers that have upgraded axles to the larger 5 on 5.5 bolt pattern this also allows them to use the smaller patterned spare tire carrier and use the larger pattern spare tire. This is three adapters in one. Also pushes the spare out and up nearly 3". This product is IN STOCK and just $64.99 and can be found Here
