Rancho® 2" Front and Rear Coil Spring Kit for Jeep® Wrangler JK/JKU
Old Jul 27, 2021 | 10:23 AM
Rancho's Avatar
Sponsoring Manufacturer
Talking Rancho® 2" Front and Rear Coil Spring Kit for Jeep® Wrangler JK/JKU
TL/DR
Our 2" coils are now available as a stand alone item!
Check with your favorite retailers on cost.
Specifically tuned to provide superior on-road comfort and off-road performance, Rancho® front progressive rate coil springs ensure that your Jeep® Wrangler JK/JKU maintains a level stance and ride – even while under heavy load or towing. These Rancho front coil springs provide 2-in. of lift height to allow the use of larger wheel/tire combinations without body modifications or fender trimming.
  • COMPATIBILITY -- Designed for Jeep Wrangler JK/JKU
  • IMPROVES PERFORMANCE -- Progressive rate springs are specifically tuned to deliver superior on-road comfort and off-road performance
  • FITS LARGER TIRES -- Provides 2-in. of lift to accommodate larger wheel/tires without body or fender modifications (aftermarket bumpers, sliders, winches affect lift height)
  • EASY TO INSTALL -- Kit includes two front coil springs that install easily
  • LEVELS VEHICLE -- Maintains level stance and ride while under heavy load or towing
  • RESISTS CORROSION -- Powder-coated to resist rust and corrosion
  • ENGINEERED TO LAST -- Made of high-strength steel that is shot peened and heat treated for long life
Old Jul 28, 2021 | 12:24 PM
Sandman17's Avatar
What's the largest tire that you can run on a JKU with stock fenders?
What size is the tire of the jeep in the picture? Thanks!
Old Aug 2, 2021 | 07:04 AM
Rancho's Avatar
If I recall that was a 35" tire.
You CAN run a 35" tire but will need taller bump stops.
We say 33" tire just to be safe.
Old Aug 3, 2021 | 11:24 AM
Sandman17's Avatar
I have 285/70/17 terra grappler g2's currently on my Jeep with the Rancho 2" sport lift w/ 9000xl shocks.
It came with bump stops for the front, none on the rear.
I'm looking to go with Nitto Ridge Grappler 35/12.5, about what would I need to do on the bump stops?
Do you sell anything that will accommodate?
Old Aug 4, 2021 | 05:54 AM
Rancho's Avatar
For out back? You will be fine since the 2" SPORT will work with the 35" tire.
Make sure the fronts were installed, because it will rub if not installed
(Some do not install the front and stay at a 33" tire no rubbing)
Old Aug 4, 2021 | 03:20 PM
Sandman17's Avatar
Great!! I absolutely love this lift, had it for 8 months and trailed it a dozen times. Perfect for daily driver/ weekend warrior but it has surprised me on how well it does on moderate (blue) trails.
For the rear, do I need to add any bump stops?
Old Aug 6, 2021 | 07:43 AM
Rancho's Avatar
IF you have the 2" SPORT then you will not need a taller bump stop out back and can run 35" tires
Old Aug 6, 2021 | 08:08 AM
Sandman17's Avatar
Perfect! Thank you for the info.
