TOTL JK Heat Expulsion Hood
#212
Former Vendor
If you choose to remount it, measure twice obviously and as mentioned one side will require a huge whole for the hooked end and the other side maybe just a small pilot hole as the bracket uses a self tapping screw.
#214
Ok just got my hood mounted. They left the wind shield washer on my old hood. They could not figure out how to install the windshield washer tube to the new hood. Any suggestions?
#215
Former Vendor
You can drill the holes out yourself. If you do this, start with a tiny drill bit and increase in size until the nozzles fit in snuggly. Also make sure to check where you are drilling from the underside so as to not have to drill through two different layers. You accomplish this by avoiding the smooth textured bracing on the underside. I have had a few customers do this and it turns out very well if you take your time.
The other option is to relocate the windshield washer nozzle into the grate located in the middle of the jeep directly below the windshield. All you have to do is cut out one front to back slot and two left to right slots and the nozzle will pop right in. Here are couple of pictures for reference.
#217
Former Vendor
If you are in the Denver/Colorado Springs area and can help:
https://www.jk-forum.com/forums/four...r-help-341187/
#220
Former Vendor
