Who makes the Best driveline for jk and why?
Sponsoring Manufacturer
JE Reel Drivelines
JE Reel Drivelines
I want to know what the people think. Who makes the best jk driveline and why?
I have always heard that woods are the best, and plan on going that route. Main reason is that they use a new yoke so you can run a longer drive shaft, and also they have their shafts polished because their workmanship is that good that it shouldn't be covered up.
Dont have any experience outside of JE Reel.
JE Reel Customer Service has been very professional and immediately replaced our 1350 front shaft when a problem occured.
My only 2 suggestions to improve on the overall product.....
Have Jim include installation instructions.... I know he's been meaning to get around to doing it
Use better spray paint and or a primer when painting the driveshafts.
i have been running Rubicon Express front and rear on a 4.5" la kit, no cpmplaints, no binding at full flex, power seems equal and smooth even at extreme angles. seems to be a very solid shaft, i keep em lubed and have performed very well for me. since these are the only ones i have run since they have never broke, i cant speak for anything else.
Tom Woods. I started with the Reels and the flange wouldn't go on the pinion. It was like it was machined a couple of thousandths too small. Finally called and was told, "We haven't heard of that one before." Later talked to a shop that had the same problem. Took 3 1/2 weeks to get a second flange, never received a return label for the first. Fortunately I bought front and rear so i could run in 2wd in the meanwhile. Went to Woods as soon as I could. Their 1310's have the easiest way of being lubed and their warranty covers both u-joint AND shaft should something happen. When I called them, they asked for a measurement I didn't have, the guy told me to go grab a tape and he'd wait....when i got back he needed another, again go grab the tape while he waited. This was Thursday evening, the shafts arrived Monday afternoon. I usually don't dog a manufacturer particularly in the vendor's section, but you did ask. And if this helps make you a better company, then it's all good.
From what i have read sounds like Woods has had the good reviews with minimal issues. Havent heard much about tera or rubicon. Heard about issues with flanges and leaking t cases with j reel. Now i understand that there is alot of operator error out there and i havent personally done a drive shaft yet. I plan to call j reel and woods myself before i make my own decision to give each a fair shake.
