WIN - The EVO MFG 4" DoubleD JK Bolt On Long Arm Kit Giveaway!!
JK-Forum Founder
Hey everyone, I just wanted to let you all know that EVO Manufacturing has just completed the development of their all new Jeep JK Wrangler, EVO MFG 4" DoubleD JK Bolt On Long Arm Kit. To help kick off its big release, they will be giving one away to one very lucky member here on JK-Forum.com AND, if that weren't enough, Off Road Evolution is even including the installation of it at their facility in Fullerton, CA!!
EVO MFG has proven to be a leader and innovator in suspension performance, creation and engineering. The EVO MFG 4” Bolt-On Long Arm Kit for the JK will certainly prove to land at the top. This system was specifically designed to enhance and surpass the overall handling on and off road of the JK. EVO has taken into account many of the factors that compile an ultra high quality and performing system. On and Off Road achievements include High Ground Clearance achieved though sleek bracketry. Greater articulation is achieved through smooth plush ride coil rates, long travel shocks and optional bumpstop heights. Increased stability is achieved through specifically tuned coil rate/shock rates, rigid and adjustable swaybar linkages and optimized roll center corrections both front and rear. The result of the EVO MFG 4” Long Arm kit is a vehicle with unsurpassed handling under all circumstances, whether your traveling on the highway or combing the Rubicon Trail, rest assured you will be satisfied with this dominant suspension system.
Features:
• EVO1 Adjustors, Full on car adjustability of control arm length, no need to remove control arm to adjust
• Complete Bolt-On Installation, Weld-On if desired, welding will not void warrantee
• No need to remove the gas tank to install
• Proven Currie Johnny Joints
• Ability to retains factory high clearance transmission crossmember
• Optimum Roll Center Correction both front and rear
• Engineered to handle up to a true 14” of Vertical Wheel Travel
• EVO 4” Plush Ride Coil Springs
• Complete with EVO MFG Drag Link Flip Kit, Steering
• All Control Arms fully compatable with EVO Ultra High Clearance Long Arm system used with the EVOLever
Notes:
2010+ models require exhaust modification which requires some welding
Cutting and Drilling Required for Complete installation
Can be installed as a weld on if desired
Available with 2 Different bumpstop options to specifically tune travel to your vehicle
Aftermarket wheels with 4.5” or less (smaller number) backspacing required
Optional: Add $800 for EVO ENVY Links, CNC Machined Billet Aluminum Control Arms2010+ models require exhaust modification which requires some welding
Retail Price: $3389.99
THE TOTAL VALUE OF THIS GIVEAWAY INCLUDING
SHOCKS AND INSTALLATION IS VALUED AT OVER
$5,000.00
To WIN:
• You need to be a registered member of JK-Forum.com.
• You need to post (1) ONE response in this official registration thread
• You need to include a photo of your JK in your post
• You need to include how many miles you live from the Off Road Evolution Facility in Fullerton, Ca.
• You must enter on or before 12:00 PM PST - St. Patricks Day Thursday, March 17, 2011.
Rules:
• A member will be selected at random to win this prize and they will be announced at the Project-JK Shamrocked Party on Saturday, March 19, 2011.
• The selected winner will NOT be required to be present in order to win this prize.
• The winner will be REQUIRED to bring their Jeep JK Wrangler to Off Road Evolution and have the kit installed at their facility within 14 days of the announcement.
• JK-Forum.com reserves the unconditional right to make changes to any and all forum Rules and/or Guidelines, including those created for special events and/or giveaways, at any time and without any prior notice. JK-Forum.com also reserves the unconditional right to determine the winner of this giveaway and, if deemed necessary by JK-Forum.com in its sole discretion, to cancel the giveaway at any time.
• There is NO cost and NO minimum post count required in order to enter this giveaway.
• Manufacturers and vendors may not enter into this giveaway and will not be eligible to win.
• Multiple posts in this official registration thread will disqualify you from the drawing.
• Entering this givaway under multiple user accounts will result in the termination of ALL your accounts.
• You MUST be 18 years or older to win.
Good luck to all of you!!
California here I come!!
I've got a 2007 jk red rock currently living in Rhode Island.
I live approximately 71 hours away -- 2954 miles!!!
Here's a pic of my pride and joy wrangler and my dog kohdy who always comes along for my adventures...
