WIN the TeraFlex CRD60R Rear Axle Giveaway!!
http://www.project-jk.com/images/giv...e-giveaway.jpg
To help celebrate the 10th anniversary of making off road specific axles, TeraFlex will be giving away a brand new JK CRD60R Limited Slip with choice of gears to one very luck member here on JK-Forum.com!! JK CRD60R Features The original & industry leading aftermarket high pinion Dana 60 Complete with axle assembly, axle shafts, HD cover Stronger bracketry than factory OEM JK specific CNC laser cut bracketry from 1/4 steel provides the highest strength Run 38 tires with confidence Maximum control arm & trackbar adjustability with multiple mounting locations Maintain factory drivability & sensor control system information JK ESP, ABS & speedometer sensor compatibility Proper pinion angle for lifted JK applications to maximize power transfer JK CRD60R Features 100% engineered, designed, and built in the USA CAD designed housing & bracketry for precision Proven tri-chamber oil system for maximum oil flow to critical bearings Maximum ground clearance (more than a Dana 44) HD oversized outer pinon bearing for superior strength & heat reduction Off-the-shelf bearings and parts for easy maintenance & repair Housing features cast ribs & gussets for strength to resist deflection Thicker axle tube than factory - 3 OD DOM tubing Premium UV protected powder coating for superior quality finish Smooth radius bottom to glide over rocks and obstacles HD 3/8 cast cover for extreme rock protection defense 100% new components used throughout for a true 0-mile axle No Excuses warranty - 1 year, unlimited mileage JK HD Axle Shaft Features Rolled splines for a stronger shaft vs. cut splines 4140 Chromoly shafts with dual wheel bolt pattern (5 on 5 or 5 on 5.5) Axle shaft profiling for improved shaft strength and fatigue resistance 35 spline shafts provide maximum strength and interchangeability with lockers and Limited Slip Trac-Lok, this Giveaway is valued at over: $2995.99 To WIN: You need to be a registered member of JK-Forum.com. Good luck to all of you!! :thumbsup: You need to post (1) ONE response in this official registration thread. You need to include a photo of your JK in your post. You need to post your response on or before 12:00 NOON-PST, May 3, 2011. A member will be selected at random to win this prize between the hours of 5:00 and 7:00 PM-PST, May 3, 2011. A Private Message will be sent to the member in question and an announcement will be made in an official thread posted in this forum: WIN the TeraFlex CRD60R Rear Axle Giveaway The selected member WILL BE REQUIRED to be logged on to JK-Forum.com and will have a total of 5 minutes to post a response in the official announcement thread. Once the official announcement thread is created, NO other member will be allowed to post in it except for the member selected to win the prize. IF the selected winner is not present or fails to post a response on the official announcement thread within the 5 minute time frame, a new winner will be selected and announced accordingly. This process will be repeated until a winner is present to claim their prize. If the winner is located outside of the lower 48 United States, they will be required to pay for ALL shipping costs and tariffs. JK-Forum.com reserves the unconditional right to make changes to any and all forum Rules and/or Guidelines, including those created for special events and/or giveaways, at any time and without any prior notice. JK-Forum.com also reserves the unconditional right to determine the winner of this giveaway and, if deemed necessary by JK-Forum.com in its sole discretion, to cancel the giveaway at any time. There is NO cost and NO minimum post count required in order to enter this giveaway. Manufacturers and vendors may not enter into this giveaway and will not be eligible to win. Multiple posts in this official registration thread will disqualify you from the drawing. Entering this giveaway under multiple user accounts will result in the termination of ALL your accounts. You MUST be 18 years or older to win. http://project-jk.com/gallery2/main...._itemId=233133 http://project-jk.com/gallery2/main...._itemId=233136 http://project-jk.com/gallery2/main...._itemId=233139 http://project-jk.com/gallery2/main...._itemId=233142 https://www.jk-forum.com/forums/imag...r-teraflex.gif |
well i guess ill start this off. I'm gonna need to edit in a photo
1 Attachment(s)
im in im in!! :clap:
Attachment 144279 |
I'll third it. I hope I win, I need it!
http://a2.l3-images.myspacecdn.com/i...e7759d13/l.jpg |
Sweet contest, I'm in.:thumbsup:
https://www.jk-forum.com/forums/atta...9&d=1299890488 Woops forgot the picture |
I need it! I break waaay too many parts!!! :naw:
Here's mine: http://i1113.photobucket.com/albums/...g?t=1301599917 |
1 Attachment(s)
I'm in. thanks!Attachment 144280
