'07 Soft Top Side Windows on '14 Soft Top?
Will the side windows from an '07 factory soft top fit on my '14 factory top? Looking to get some trail windows that I won't care how much they get scratched.
Don't know exactly, but they changed the size of the rear window. Maybe in 2010?!
Have read a thread on a german forum where someone had trouble with top and windows from different model years. I think he had newer side panels and the older rear window which resulted in 2" gaps on either side. If your setup would fit, it would be more of a loose fit I think. |
Not so worried about the back, but the sides. Any idea what a good price to pay would be?
Originally Posted by ShutterBug
(Post 3888849)
He had a 2013 top with the window set from an older model. According to him he only had issues with the rear window while the sides fit perfectly. So I assume the side windows are interchangeable through the model years, but I hope someone with first-hand experience will chime in. Don't know about the pricing. |
Originally Posted by crusaderJK
(Post 3888855)
Have checked the mentioned thread again.
He had a 2013 top with the window set from an older model. According to him he only had issues with the rear window while the sides fit perfectly. So I assume the side windows are interchangeable through the model years, but I hope someone with first-hand experience will chime in. Don't know about the pricing. I can only assume the same holds true for the 4dr, but no first hand experience. |
The windows changed for the 2011 model year. I have never tried myself, but don't think they're inter-changeable.
Originally Posted by LidLess07X
(Post 3896049)
Only the rear window got wider on the soft top. On the hard top, both the rear AND sides were enlarged. This leads most folks to assume that the sides on the soft top were enlarged also. Easy to make that assumption, I made that assumption myself until I had both tops on hand. Based upon pics I have seen, I have a high degree of confidence that the 4dr is the same way. |
Originally Posted by jeep_n_co
(Post 3896095)
Once again, any year side will fit any year top on the 2dr. As stated, I have first hand experience putting a post 2011 side on a pre 2011 top, and vice versa.
(Post 3896122)
That's good news for the OP. I'm just clarifying the model year they changed. So only the clear area of the soft top windows increased in size for both 2 door and 4 door models 2011+?
The clear plastic area of the side windows did not appear to me to be any larger on the 2dr. |
