08 vs 09 hardtop
Is there a difference between the two yrs? A friend went to pick up a hardtop from a 09 and the middle loop bracket that I thought was to strap the windshield down is moved over from dead center. The 09 freedom top panels have a latch that lines up with the loop bracket but would not line up with the bracket on the 08. Is this correct or did they do some thing wrong?
I must be lucky, My '08 has never leaked. Even in torrential downpours, pressure washing, car washes, etc. Going on 10k miles, hopefully the trend continues.
I have never had any issues with the top on my 08 other than when I have been in a hurry and pinched some of the weather striping. Also with the 09 top on an 08 you will actually lose the tension between the center front of the two panels unles you move the footmans loop.
09 owners beware that the change may have been made after a few of the 09's were on the market. I just ordered a rear replacement shell for my 09 ( one side got dropped on the cement and bashed the fiberglass
) The dealer was about to place the order then came back needing the vin as he said his system was showing a change.
On the 07/08 the front latch in the center latches the two panels together. On the 09 it only latches to the footman loop (which is offset by about 3") so you would probably leak if you tried switching to the 09.
SWEET!
