0W-20 motor oil on a new Jeep
Old May 21, 2014 | 10:55 AM
scubatech's Avatar
Thumbs up
Originally Posted by JKZinger
0w will cause less wear at startup than 5W no matter where you live. It is the cold oil number and has no bearing on the ambient temperature once the engine is warm.
According to AllPar, Mopars own performance site you should always use 5 W 20 for VVT engines unless otherwise specified. According to these engineers the lifters need this specific grade of oil to live a long life and perform as designed. I doubt any gains would be noticed. % W 20 oil is pretty light wieght and flows really well when cold and can live with high oil temps in synthetic form.
Old May 21, 2014 | 01:57 PM
rob_engineer's Avatar
Yep, but my 2012 pentastar specifies 5w-30
Old May 21, 2014 | 02:07 PM
Grimmjpr's Avatar
Originally Posted by rob_engineer
Yep, but my 2012 pentastar specifies 5w-20.
Don't you mean 5W-30?
My 2012 calls for 5W-30.......which is funny cause all the 13-14's call for 5W-20 and my GFs 2013 Avenger R/T calls for 5W-20 as well......
Old May 21, 2014 | 02:52 PM
Chefbrujo's Avatar
ya thats what i was trying to say. However what another person mentions about thenlighter weight drainin more thoroughly seems to logically make sense too. Hmmm which one is better for stabing of. long term start up wear.
Old May 21, 2014 | 03:21 PM
Originally Posted by Grimmjpr
Don't you mean 5W-30? My 2012 calls for 5W-30.......which is funny cause all the 13-14's call for 5W-20 and my GFs 2013 Avenger R/T calls for 5W-20 as well......
Yep, sorry. 5w-30 for the 2012. (Typing on iPhone in dark room.)
Old May 21, 2014 | 03:29 PM
Jiblet's Avatar
The oil will hardly all drain off. Just doesn't happen.
Even if it did, that's where the additive packs come into play. They lay down protective layers for instances of boundary lubrication.
Anyway, people shouldn't make many sweeping generalizations or comparisons between grades of oil without specifying brand/type.
Not all 0w, 5w, 20, 30s are the same. You have to look at all various parameters. And that requires trusting the companies to keep the PDS up date (and accurate).
Check out pqia for example
http://www.pqiamerica.com/Feb2014/co...ed5w20ALL.html
Old May 21, 2014 | 05:38 PM
Jeepstin12's Avatar
interesting. My cap and manual states 5w-30...
Old May 21, 2014 | 06:00 PM
Please see that I corrected myself. My 2012 specifies 5-30.
Old May 21, 2014 | 06:09 PM
Jeepstin12's Avatar
I saw that afterwards. No worries. I thought perhaps jeep had some discrepancies and was wondering if maybe they changed midway through 2012.
Old May 21, 2014 | 08:14 PM
5150cliff's Avatar
This comment is absolutely correct. The lower the number, '0' in this case, the better the start up protection. The temperature has no bearing on it. So, running 0-20 or 0-30 is fine. All those who say that they run a 10 weight or even a 20 weight oil because the air temperature in their neck of the woods is over a certain degree are totally misinformed.
