2012 Auto? MUST READ-Trans line rub causes leaks!
My 2012 JKU had a major transmission line leak at 5,000 miles.
The tech said it was due to power steering line rubbing against the transmission line behind the drivers side wheel well. When he installed the new trans line he bent it away from the power steering line and applied some foam to protect it. He said had he installed it stock it would have likely rubbed through again. (Service report is below)
Below are pictures of where the leak occurs (according to my internet search this is becoming all too common on the new 2012 autos)
This picture is of the differential cover paint which was taken off from the hot trans fluid leak. (picture is upside down)
I checked the four 2012 autos on the dealer lot and 2 out of 4 were touching and will likely rub together and in my opinion may leak as well!
So check your lines and make sure they are not touching. If they are, you might want to talk to a service tech to see i they can prevent a leak.
Wow thanks so much for documenting it all and working on those pictures. That takes a lot of effort, thanks. I'll have to check mine soon before my move from Ohio to Texas.
Attachment 337604Attachment 337605Attachment 337606
Attachment 337607
This picture is of the differential cover paint which was taken off from the hot trans fluid leak. (picture is upside down)Attachment 337608
Attachment 337607
I've got a 12 Rubi 2dr. Looks nothing like this at all. 2-12 build date.
As I understand it my leak was at two places- at the entry into the radiator and on the line- so as long as they are not rubbing then I would think you should be good.
Try to get pics, within 2 hrs maybe.
