3.6 Cam Follower Problem - JK-Forum.com - The top destination for Jeep JK Wrangler news, rumors, and discussion
Sponsored by DV8 Offroad
Click Here
Old 02-04-2019, 12:15 PM
crosstowne's Avatar
Default 3.6 Cam Follower Problem
My 2012 JKU is in the shop have the cam followers replaced. It has 125,000 mi. on it, mostly city driving. It always had valve clatter on startup but it got to the point where the tapping didn't go away.
I had the left side head replaced at 71,000 mi. on the recall. That seemed to have gone alright.
I've changed oil at 6,000 mi. religiously and used Mobil 1 5-30 every time. It's very frustrating. I was hoping to get a lot more miles before having engine problems.
Anyone else seen this?
crosstowne is offline
Old 02-05-2019, 09:27 AM
rob_engineer's Avatar
This is the first instance I recall seeing in this forum of cam follower problem. In fact, so far the 3.6 engine seems to be holding up very well, other than the left side head issue you mentioned. Don't brag to the dealer about using Mobil 1 oil because Mobil 1 does not carry the certification for the Chrysler spec. That is why I do not use it. I have the lifetime max care warranty and don't want to give the dealer any wiggle room to deny a claim.
rob_engineer is offline
Old 02-06-2019, 06:26 AM
crosstowne's Avatar
[color=left=#333333]Thanks for the reply Rob_Engineer. They are not doing it under warranty anyway. About $1,300 estimated.
I did find this on moparmagazine.com:
A STAR Case bulletin, S1309000016, was released just over two years ago (March 18, 2014) in regards to the rocker arms used in the Pentastar® engine. The symptom/vehicle issue is ticking/tapping noise from the upper engine area. In addition, this failure can also set a Diagnostic Trouble Code (DTC) for an engine misfire.[/color]
[color=left=#333333]Remove the components to gain access to the engine valve train. Inspect each rocker arm roller bearing for missing or worn needle bearings. Also, inspect for a collapsed valve lifter. Replace, as required. This condition is typically found on vehicles with mileage accumulation of 15,000 miles or more.[/color]
Quick Reply: 3.6 Cam Follower Problem
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
