4 pin plug not working
Discovered my 4 pin plug was not working when I hooked up my flat trailer. Called the dealer and they said my jeep may have to be programmed to recognize the tow wiring harness? Anybody heard of this before?
Do you also have the 7 pin harness installed?
When I added the 7 pin harness to the Jeep, the 4 pin stopped working. I opened up the driver's side rear tail light and rearranged the order of the plugs so they were all in series. That fixed the problem and now both the 7 pin and the 4 pin work.
Originally Posted by Poker5150
Im assuming youre talking about the 2 plugs that plug into the rear tail light assembly. My taillights work perfectly so how would this be a potential problem??
I would check to make sure the ground wire in the connector is actually grounded. Use the continuity function on the multimeter to check continuity between the ground wire in the 4-flat connector and some unpainted thing such as a bolt connected to the chassis.
