4 Wheel Low question
Old Nov 13, 2012 | 02:45 AM
  #31
ewbaker's Avatar
Default Torque
Try putting in 4L on the steepest hill you can find. There's a ridiculously steep hill heading out of Port Jeff Village going West on the North side 2 streets after the deli. I have no idea how they paved it to be honest. Any really steep hill will work, but if you go to Port then I can check out your rig. :-)
Let out the clutch and don't give it gas 1st gear. It'll just crawl right up the hill. effortlessly. The motor won't even strain. Yeah it's really slow but you'll really like that in certain situations. Add the lockers to the mix and it's falling in love all over again.
Don't turn on dry pavement in 4 wheel high or low. Your avalanche had a center diff which allowed the front and rear axle to turn at different speeds (if it was AWD). Jeep doesn't have that. (wranglers anyhow) I think the avalanche had a center diff lock as someone already said. That was the "L" I'm guessing.
You probably know this, so sorry I'm for droning on.
Old Nov 13, 2012 | 11:01 PM
  #32
powrsurg's Avatar
Originally Posted by lkjk
you have a ton of mods based on your sig...did it come that way? Just surprised that you haven't been in 4lo with everything you have done to It
I just finished my build sheet for the exterior. Didn't want to take it off road until I was finished. May go to R Creek this Sunday. Been on the beach but aired down didn't even need 4 wheel.
Originally Posted by FlameRedJK
I'm sure the Jeep gets around the mall parking lot just fine in 2Hi :P
Yes, and you should see what it can do to unattended shopping carts.
Old Nov 15, 2012 | 04:28 PM
  #33
zstairlessone's Avatar
So here's a way to see how much more torque you have in 4lo than 2hi or 4hi. In 4lo start out in first and drive around 2000 RPM, keep your foot on the throttle and using the other foot try to stop the jeep. Note how hard you have to push the pedal to stop. Now put it into 4hi or 2hi and go the same speed, maintain your throttle like in 4lo and see how much brake it takes to stop the Jeep and kill the engine. If you had an automatic you could do this much easier - that's why people have to put big brake kits on a rig with three speed transfer cases with super low gearing, can't stop the creep with the OEM brakes due to the torque multiplication. You wont go fast in low range, but your flywheel torque is converted back to a larger torque at the wheels due to the gearing.
Old Nov 15, 2012 | 05:33 PM
  #34
powrsurg's Avatar
Im going to Rausch Creek on Sunday. I wil baptize the Jeep then. Sure Ill have cause to use 4lo there.
Old Nov 16, 2012 | 12:44 PM
  #35
EzK's Avatar
EzK
I'm in 4 low there 98% of the time! Enjoy it.. Doing anything harder than greens?
Old Nov 16, 2012 | 12:47 PM
  #36
powrsurg's Avatar
No, I'm taking it easy my first day I hope. Depending how comfortable I feel on the greens, I may try a blue. We are going next Saturday now, not this Sunday.
Old Nov 16, 2012 | 01:01 PM
  #37
skunk709's Avatar
not sure if anyone asked, but were you shifting your chevy into neutral before shifting to 4LO?
Old Nov 16, 2012 | 01:08 PM
  #38
powrsurg's Avatar
I would come to a complete stop and I believe first had to put the avalanche in neutral. I can't remember for sure as it was 10 years ago.
Old Nov 16, 2012 | 01:11 PM
  #39
TURTLECON's Avatar
My avalanche was push-button 4WD. I didn't have to go in N, just stop or coast under 5-10mph for 4-lo.
Old Nov 16, 2012 | 01:14 PM
  #40
powrsurg's Avatar
Yes you are right. Confused the avalanche with the Cherokee I had before. The avalanche was all push button and I never needed 4l other than to test it. The avalanche on Nitto Terragrapplers was SICK!!!
