4X shifter Question
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Is it normal when shifting into 4HI and back to 2 Hi for the shifter to seem stiff or slightly hard to move?
Thanks.
Thanks.
It depends on the load on the drive train. If you are in gear and your speed is changing, either increasing or decreasing, then you have a load on the gears and that will make it more difficult to switch in and out of 4 wheel drive. I always push in my clutch when shifting in or out of 4 wheel drive and I have no stiffness issues. In my wife's Sahara, I slip the trans into N when switching in or out of 4 wheel drive.
Yeah its stiff, practice popping it in and out of 4wd with the tranny in neutral and with a slight roll speed, your hand will "learn" the best speed on the shift and it will become second nature....
the Jks t-cases are built to shift at a slow rolling speed. its on the fly 4wd. i cant quote the manuel but u should be rolling 2-4mph and shifting so the teeth can engague properly. if you try n shift at a stand still with an auto atleast you are asking for trouble down the road.
