4x4 shift knob
Old Oct 18, 2011 | 05:03 AM
weebus's Avatar
Default 4x4 shift knob
anyone know how to remove the 4x4 shift knob? i dont want to start yanking on it and break it it seems it has to be removed to lift out the console
Old Oct 18, 2011 | 05:44 AM
tjt94's Avatar
I twisted it with a pipe wrench and it did pop off. Then I discovered the better way.
Take a small screwdriver and separate the rubber collar from the top of the knob. You then slide that down and the internals will be exposed. You should be able to see what is next.
The knob is held on be a spring clip that is pretty strong. Putting something like an openend wrench under the knob and hitting upward with a hammer will pop it off too.
Good luck.
Old Oct 18, 2011 | 05:47 AM
HappyCurmudgeon's Avatar
Eternal ***erator
pull until you are purple, just dont chestpunch yourself.
Old Oct 18, 2011 | 06:06 AM
Zroe's Avatar
I removed the rubber part with 2 flatheads on either side and some muscle. Then took a big ass wrench and muscled to turn it 360 a couple slow times, then was able to shimmy it up with the wrench. Same process for the gear shifter.
Old Oct 18, 2011 | 06:10 AM
Eternal ***erator
I have been digging for an old thread on this where someone posted pictures of how to pop the knob apart to remove the spring clip, but I'll be damned if I can find it.
ibsurchwetodded
EDIT: nevermind (ok, i am still wetodded, but), here is the link i was thinking of:
How to remove your transfer case / 4wd knob
Old Oct 18, 2011 | 07:32 AM
shoe1724's Avatar
I have a 2011 and was pulling on the t-case knob until I was about to pass out. Thing didn't move. Someone told me to put a crescent wrench on it and then a few hits w a BFH and it pops right off. Haven't tried it yet though.
Old Oct 18, 2011 | 08:05 AM
muddenjeep's Avatar
I gave myself a fat lip doing taking mine off.
Old Oct 18, 2011 | 08:37 AM
TURTLECON's Avatar
LMAO at "chestpunch"!!
Old Oct 18, 2011 | 08:59 AM
The_Yeti's Avatar
Once you pull your knob off a couple of times its pretty easy and you dont have to fight it.
Old Oct 18, 2011 | 09:12 AM
Orangeav's Avatar
I had to replace the boot and bezel around my shifter this summer and all the stuff I read about people getting fat lips and black eyes and chipped teeth when removing the shift knob had me pretty nervous. I sat on the center console and got prepared for a battle. To my surprise, it came off super easily for me, T-case handle too (I removed it just to see if I could). I was one of the lucky ones I guess, still have all my teeth, and the fat lip is from buying parts without telling my wife first..."Telling" is a manly way of saying asking!!! LOL!!!
