60k Service Question
Sorry if this has been discussed before, but I'm a bit of a newbie when it comes to the mechanical side of things.
I'm set for my 60k service and I know my dealer is going to give me a list the length of a cvs reciept for what they want me to get done. Now, I read the owners manual and know what it says I should do, but I'm wondering if there is anything else I should get done? Or are there things I don't need to get done that the manual says I do? I have a 2013 Wrangler Unlimited. I don't tow or off road. I only drive it 1-2 a week since I take a bus to work. It's a manual transmission. |
All you need is front and rear diff service, tcase service, filters, oil change, rotate...... Coolant and trans is not needed until 150k, tune up is due at 100k, but they will try to hit you for all the snake juice you could handle.
Unless you have to do the service to maintain a warranty, not worthwhile for the cost IMO. it takes 10 mins to change gear oil in an axle, and not much longer to change the ATF in the transfer case, although a just a touch less convenient. Pretty sure you probably stay on top of oil changes, and anyone can pop a new air filter in there from time to time. I'm not saying things don't need to be done, but the prices I've seen people report dealers charge for things like axle fluid change are redonk. You can't grease factory steering components, and they have a tendency to let you know when they are shot, so any "inspection" won't lead to much.
If you can, do the work yourself. If you can't, find a mechanic you trust and have him do the work. Quick oil change places can often do all of the work for these periodic checkups, and they're cheaper. If for some reason you feel obligated to the dealer (it's not necessary for warranty purposes), write down what you want the dealer to do on a list. Not, "60,000 mile checkup", because he'll take that as carte blanche to do everything under the sun. Write down, "Change engine oil, rotate tires ...", or whatever is needed. Say that's what you want, and nothing else. I would recommend have them check the brakes, especially the rear brake pads. If they are original, they are likely worn. In fact, you may have run them down so far that the disks need replacement.
(Post 4343941)
Just changed the brakes recently so we're all good there. I'll definitely makes a list per the recommendations above. |
Originally Posted by resharp001
(Post 4343896)
Originally Posted by anon1mous
(Post 4343966)
I live in an apartment so not really convenient to do the work myself, and I really haven't found any Jeep oriented shops in my area that I'd go to. The dealer offers free oil changes, which is the only reason I still go there.
But, I understand your situation. That would suck working in an apartment's parking lot. From the sounds of how lightly used the jeep is, I'd be willing to push things off 10k miles or more, but that is just my opinion. |
The dealer will try to rob you on the differential oil changes. As others have said, it is simple, actually as easy as changing oil. I think an independent shop would charge less than a dealer.
Originally Posted by rob_engineer
(Post 4344025)
The dealer in Las Vegas charges $180 per axle for the diff fluid change. It is worth it to buy the pan and the tools and change it in a parking spot. there is a drian plug and a fill plug on the D44s not sure about the D30s
