AC on JK seems to lose chill every couple minutes
I just got a new JK unlimited last week and the AC has been kind of bugging me since I notice it. I can turn the AC all the way to cold and it definately gets cold for awhile, but then i'll notice it warm up or lose it's chill almost like I turned the outside air on for about 10-15 seconds then it get's it's chill back again. I mean it's not uncomfortable it's just enough that I notice it. It seems to get like 5-10 degrees warmer and then cools back down. It's almost like it's cycling or trying to get enough energy to cool it back down for another minute or two. Also, It'll do the same thing whether it's on recirculate mode or just regular AC.
Does anyone else have this issue or does your AC seem to stay the same temperature always? I'll probably have the dealer look at it but was just curious if I'm not alone. |
It is normal for the A/C to cycle on and off. Does it keep the cabin cool?
I would have it checked out at the dealer, is your radiator clean?
Red |
Originally Posted by RedneckJeep
(Post 1082203)
I just called the dealership and explained the issue. They think it could be low on freon or another issue but said it should stay cold and remain cold. Gonna take it in tomorrow. |
Originally Posted by TheonlyREDhead 2008 JK
(Post 1082267)
Red |
I'll bet its cycling on the low limit. meaning in english, it might need some refrigerant.
This is normal operation of all AC units. It depends on what else you are doing with the vehicle. If you are trying to maintain 80mph with the AC going, there just isn't enough power under the hood to do both, so the AC will cycle.
Try out your system at idle and it should blow cold continuously - if not, I agree take it in to get looked at. |
Originally Posted by silvel2edge
(Post 1082430)
Eh, My Highlander doesn't do this... it remains Ice cold at all times. My Mustang didn't do this either.
Well the evac'd the system and replaced the freon and it's still doing it. Grr... now I have to leave it there so they can finish working on it on Monday. He said they think it might be some gauge or thermostat part or something though they said it's not throwing any codes in the "star" system and they haven't seen this on any wranglers so far.
(Post 1084952)
