Accessing the inside of the Tailgate door.
Old Sep 26, 2012 | 08:59 PM
powrsurg's Avatar
Default Accessing the inside of the Tailgate door.
How accessible is the inside of the back door? Im thinking of installing an air tank on the door but will need to drill holes, fit a bolt through it. If I had to put a nut on the bolt that is inside the door would it be possible to reach it with a wrench?
Old Sep 27, 2012 | 02:53 AM
westchester's Avatar
Once you remove the outside plastic vent, there's enough room to get your hand/fingers partially inside. Just be careful not to break the vents upper clips, ease it off slowly without too much force and you'll be good.
