alternator problems!
Old Sep 22, 2012 | 09:36 AM
dlincoln91's Avatar
Default alternator problems!
Last night my jeep started acting up. I have a hypertech programmer which runs the idle speed up with drawing high amps from the motor. Last night my jeep started to squeal and then this morning i started it to see if it was still doing it and i realized somehting was burning. Sure enough i open the hood and the alternator was smoking bad. I turned the jeep of and it continued to smoke so i went to unplug the battery. I am very glad i did because the positive cable was smoking hot.
So now my question is obviously it has to be replaced but has anyone seen this?
What should i do besides just replace it?
Any help is appreciated.
Old Sep 22, 2012 | 09:49 AM
carolinajk's Avatar
there is a short , possibly your battery. pull cables and ck for continuity between pos and neg cables if there is continuity then disconnect alt , but i bet the battery is toast and alt poss as well
Old Sep 22, 2012 | 02:47 PM
dlincoln91's Avatar
but how would it randomly happen while driving and continue to drive fine along with the radio,a/c working? would that affect it? also it still starts
Old Sep 22, 2012 | 03:33 PM
ronjenx's Avatar
Another source of heat at the battery terminal is a loose or corroded connection. Either one will increase the resistance, which generates heat.
Old Sep 22, 2012 | 03:48 PM
carolinajk's Avatar
the way you described it i thought it was the first time and then started smoking in any case i would or have my batt load tested and then go from there . with any electrical problem always start with the battery and go from there
Old Sep 22, 2012 | 06:03 PM
dlincoln91's Avatar
well got it checked and battery is good its the alternator bearings are burned up. im getting it rebuilt.
thanks for all the help
Old Sep 22, 2012 | 06:33 PM
ronjenx's Avatar
That explains the alternator part of your problem. I don't see how it addresses your hot battery terminal, though.
Old Sep 22, 2012 | 07:28 PM
carolinajk's Avatar
maybe the bearings were so shot that it allowed the stator to contact the inside of the case in effect a short very little clearance in there anyways
Old Sep 22, 2012 | 07:29 PM
ronjenx's Avatar
Could be. (Rotor?)
Old Sep 22, 2012 | 07:34 PM
carolinajk's Avatar
Originally Posted by ronjenx
Could be. (Rotor?)
rotor u right stator is in side of case
