Anyone change bulbs in their instrument cluster?
Old 11-02-2009, 05:33 PM
BullandTerrier's Avatar
Default Anyone change bulbs in their instrument cluster?
Has anyone changed the bulbs in the instrument cluster to a different color? Can it be done? I've been searching and can't find the bulb size and/or quantity needed. Any pointers? Thanks
~Jenna
Old 11-02-2009, 05:45 PM
jeepnxj3's Avatar
No it can't. I looked into it (took the cluster apart) and they are LEDs soldered to a circuit board. Not as easy as the tjs
Old 11-02-2009, 05:47 PM
Bummer. So if one goes bad, you have to replace the whole thing?
Old 11-02-2009, 06:01 PM
GoodysGotaCuda's Avatar
Yes if the 1,000,000 hour life of the LED happens to come to an end. You need a new cluster
Speedzter (11-13-2021)
Old 11-02-2009, 06:02 PM
Ice
Ice's Avatar
Your chances of one going bad is next to nil. Thats the reason Led's replaced bulbs in almost every cluster being manufactured. I work for a company who makes the instrument clusters and Im involved in the testing of the circuit boards. the down side is you cant change the colors of the LED's because different colored leds require different voltages to fire them. for example red usually only requires 1.9 volts to light up where blue requires about 4. in the strange event you had an led go out on a telltale or something the car manufacture should treat it as a warranty condition because of a saftey related issue. I sriously doubt this would happen though.
Old 11-02-2009, 06:57 PM
RobtTxRubi's Avatar
So anyone know how to dim the stupid high beam light?
Old 11-03-2009, 03:57 AM
bazillus's Avatar
The easiest way is place a dark, semi-translucent foil or something similar between the led and the icon in the instrument cluster
Old 11-03-2009, 04:07 AM
SCF
SCF's Avatar
black electrical tape works well.
Old 11-03-2009, 04:10 AM
bazillus's Avatar
but it's not "dimmed" then
Old 11-03-2009, 05:13 AM
RedneckJeep's Avatar
Colored scotch tape works well.
Quick Reply: Anyone change bulbs in their instrument cluster?
