Sponsored by:
Sponsored by: DashLynx
Autozone Duralast AGM Battery any comments?
Old 07-13-2012, 05:11 PM
goldtr8's Avatar
Default Autozone Duralast AGM Battery any comments?
The battery on the 08 Ruby gave up today. Jeep sat for a week and this morning would not crank over, put on a battery charger and it would start but the battery needs to be replaced.
I was going to just get an Autozone Duralast Gold but now they have a Platinum AGM battery.
I did a search and there is not many comments about the battery that really have any experience with it. Price is $149 with a 3 year replacement warranty.
Are these batteries good or just ok, they are made by Johnson Controls.
Thanks
Don
Old 07-14-2012, 04:23 AM
goldtr8's Avatar
So no one has tried one as there are no comments
Does that mean I get to go first?
Old 07-14-2012, 04:42 AM
8000ft's Avatar
I guess so.........I've got an '09 that I think will need one soon. I found an Excide glass mat on Amozon for about the same price.
please re-post with comments on what you get so others can benifit from your findings. I think there will be alot more of us needeing new juice as we aproach the 5 year mark.
Old 07-14-2012, 04:46 AM
goldtr8's Avatar
8000FT are you close to Silverton area? I am planning a run there the second week of September, I want to run Black Bear and the Alpine loop.
Any comments or advice?
Old 07-14-2012, 04:53 AM
efan450's Avatar
I don't have any experience with that brand but from what I've heard if you can spring for the extra cash, optima batteries yellow top model seems to be the most popular choice, fwiw. Do you use a winch, have a stereo system, or are just generally hard on the battery? If not i would say you would be fine. Go with at least a 600 or 650 cold cranking amps and you should have good luck
Old 07-14-2012, 04:56 AM
archijeff's Avatar
Blue cap optima is marine grade. Just purchase one for daughter rig at advance auto for $202 with $25 mail in rebate. It's all I will ever use
Old 07-14-2012, 04:57 AM
goldtr8's Avatar
Its a 720 CCA plus I do use my winch and also a HAM radio that is used a lot that also puts a load on the system.
archijeff's Avatar
Also, it's 850+ CCA and some are 950+
Old 07-14-2012, 06:38 AM
isolated1523's Avatar
You really shouldn't post the same topic in multiple forums....kinda annoying
Old 07-14-2012, 11:46 AM
Ryan0260's Avatar
Spend a little extra and get an Optima yellow top
Quick Reply: Autozone Duralast AGM Battery any comments?
