Axle bearings = wheel bearings
Hey all. My first issue w/ my 08 JKU. Getting a hum / growl from drivetrain and dealer says its bad wheel bearings (only have 38k on the odo). Wants to replace under extended warranty which has a $100 deductable.
BUT, shouldnt this be covered by my lifetime powertrain warranty? That covers axle bearings, but are they the same as wheel bearings? Thanks in advance for the help.
x2, hub bearings are not covered, but the good thing is they are pretty easy to replace, if you can do brakes your are only 2 steps away from replacing a wheeling bearing.
So, with all that. If you only need to pay $100, I would go that route!
Josh
I read up that replacing the hub bearings wasn't too bad, just didn't know if it was the same as the axle bearings. Thanks guys for clarifying. I'll have the dealer do it for the deductible since it's only $100 and confirm parts. Appreciate the advice
Anyone get denied warranty on bearings or other drivetrain issues because wheel spacers and/or 2.5" lift? I have Spidertrax spacers along with a TF 2.5" coil lift and I am noticing a humm sound from the rear of the Jeep, but only when the accelerator is pressed and it starts at around 10 mph. I dismissed the possibility of tire noise because I only hear it while accelerating.
