Axle U-Joint Replacement
I've looked on the Forum but I've not yet found a post dealing with the replacement of axle u-joints - can anyone point me to one? Thanks! (If it matters, I've got an '07 Unlimited with a Dana 44 and I am replacing with the standard Dana Splicers.)
if you have a u-joint removal tool, it's real simple. let me see what i can find for you
By the way WOL, how are the RCV axles holding up in Little Nemo? I am curious to see how well you guys like them compared to U Joint axles.
Thanks,
Remove front brakes. Remove knuckle. Slide axles out. If you don't have the correct tool, a vice and BFH works great
Let me know if you need better directions (Dos XX is taking effect) and I will print it out and fax/email it to you.
Oh, not sure if they have circlips on the caps, you might wanna check for that before you start pounding away with a BFH.
[QUOTEOh, not sure if they have circlips on the caps, you might wanna check for that before you start pounding away with a BFH.[/QUOTE]
The stock D30's looks like it has no clips.
Does it get pressed out like any other ujoint?
After removal , can I put in joints with clips? Or do I need OE joints? And do the OE joints get pressed in line normal?
