back window zipper jam
Old Sep 8, 2014 | 03:36 PM
plemmajk10's Avatar
Default back window zipper jam
How the **** do I fix it, stupid soft yop zipper on back window is jammed, looks like all hope is lost
Old Sep 8, 2014 | 03:58 PM
Blonda's Avatar
When that happened to us last month, after several attempts and about 30 minutes of trying we were about ready to tear the thing. We just gave up and next morning had a friend try and he got it right away. I've seen that happen to other people as well. Sometimes it just takes a different perspective. That being said though...I think it's time we got some zipper wax on there to help prevent it from happening again in the future.
Old Sep 9, 2014 | 11:40 AM
plemmajk10's Avatar
Hell if it were june amd I loved I like Arizona I woulda just sold the top as is and waiyed lllllll summer and then got the hard top haha
Old Sep 9, 2014 | 12:08 PM
vkoot's Avatar
I just got sick of it and cut around the stuck zipper and took the whole back window out. Been without a back window for a few months now.. no harm done.
Old Sep 10, 2014 | 10:35 AM
LOST's Avatar
I'd just take it to any boat awning or upholstery shop and have them put a new sliders on. Simple job, takes about 5-10 minutes. Shouldn't cost more than $20.
Might as well replace both sliders while they're in there.
Should be a #9 coil non-locking slider. If they have a marine grade stainless steel slider it's worth the extra $5.
If it's jammed in place they can just cut it off before putting the new slider on.
Afterward rub candlewax into the zipper teeth to keep it sliding smoothly.
Old Sep 10, 2014 | 11:00 AM
catahoula's Avatar
Quick fix I have been doing is....the zipper has spread out and needs to be squeezed close together. If you look at the other zippers that are working well compare them. It works for a while. I have been getting frustrated and forcing. I think I am headed towards a Trex or Rampage top.
Old Sep 10, 2014 | 12:39 PM
Jiblet's Avatar
It's important to start the zipper with the teeth perfectly aligned. It's too easy to insert the pin too far into the slider.
I start the window without the tail gate bar attached so it's easier to manipulate.
Keep trying to get the teeth aligned perfectly once (which is hard to do with your hand blocking your view) then take a yellow or silver Sharpie marker and make a mark across both zipper tapes about 3-4 inches above the starting point.
Now you can see that you're lined up nicely before zipping further.
Having it aligned makes it easier to get around the corners which is where I used to get stuck all the time.
Old Sep 10, 2014 | 06:29 PM
FDHog's Avatar
One of the reasons I never take my rear window completely off………..
Try spraying some silicone on it and going back to it with a cool head.
Sometimes when you're pissed off things are tougher than they seem.
Old Sep 10, 2014 | 07:01 PM
Scvette01's Avatar
FYI
There is a bulletin for a issue of not being able to disengage the zippers for the rear window.
having mine fixed under warranty
