Bad Highway Throttle Response
Normally, a vehicle driving on the highway would accelerate at a steadily rising RPM until you depress the accelerator all the way to the floor to kick in "passing gear". But in Jeeps, if you are going down the highway at 2200 RPM and want to just accelerate a little bit, it gets kicked into "passing gear" and ramps up to about 3000 RPM immediately. The same thing happens at like 3000 RPM - gets ramped up to about 4500 - 5000 RPM immediately. What is up with that? I have a 2012 JKUR now but my other 2008 JKU did the same thing. Is there any way to fix this? I wish it would just accelerate steadily as I push the accelerator down and only hit "passing gear" when I depress the accelerator all the way to the floor.
Yes, but this doesn't seem to shift. But when I think about it, it must be downshifting. But this is irritating because it's not like I'm hammering the gas pedal. I'm just trying to get it to accelerate slightly.
Either turn off overdrive or re-gear. Pressing a button is free, the other is ~$1000. The next gen Wrangler will more than likely have a modern 6 or 8 speed auto to keep the engine in the power band.
Yes, it is annoying. This weekend I was going up a hill at around 3000 RPMs and it suddenly ramped up to about 5600 RPMs - I let off the gas immediately because it sounded like it was going to blow.
