Best bumper for weight distribution hitch?
I need to use a weight distribution hitch for my trailer. The way this works is to try to twist the receiver to throw so e weight on the front wheels. The stock hitch is not very strong for this application. What is available that would work better with a weight distribution hitch to minimize the torsion? 2012 JKU sport with max tow package.
What you really need to pay attention to is receiver height if you are lifted. WD hitch receivers don't have as much drop as a plain receiver ball can have. My LJ used a 10" drop ball and I could not find a WD hitch that would go that low.
The stock hitch is mounted straight to the frame witch would be stronger than any bumper. A jk max tow is 3500lbs so that type hitch is over kill to the tenth degree. The problem with a jeep towing anything bigger is more a wheelbase issue than a power issue. So throwing a hemi and big brakes won't make it a better tow rig.
I just got back from an 1100 mile trip towing my toyhauler. I didn't have the Harley in it and water tanks were empty. Weight in that configuration is just over 3500. However, I have towed with the trailer loaded so weight was about 4500 pounds. Absolutely no performance difference between 3500 and 4500 pounds. Much of the power drag is due to the bad aerodynamics of the trailer. Even towing my unloaded landscape trailer has similar power drops because of the loading ramp sticking up like a sail in the back. I take all safety precautions. Great dual axle brakes, brake controller, sway controller, driving at grandma speeds. Mpg on my 2012 with max tow and manual trans averages about 11 with the heavy toy hauler.
If your height will be good then a receiver hitch on the bumper should be as good as an after market hitch that ties into the frame rails. On my TJ I had to go with a Shrockworks bumper as they were the only ones who rated the receiver for towing, at the time everybody else took the easy way out and said not rated for towing. For the JK Shrockworks did not include a receiver hitch. Try looking at Ace Engineering they make a very solid bumper rated for towing.
For those that wonder, all though it's true that almost all of the receivers on any good steel bumper are more than solid enough to tow. I want a manufacture that said it was rated to tow. That way some ambulance chasing lawyer could not twist the fact that it was not rated into my negligence.
I use a Reese weight distribution hitch on my 2012 jku, and it works fine. Although I have not had any issue whatsoever, my overly cautious side has had the same concern as you. Namely the twisting force on the rear crossmember. Hit me up if you find a solution. Be mindful of the other advice above to start out with the hitch ball at the proper height - my understanding is that the natural height of the hitchball, without the trailer attached, should be such that the top of the ball is slightly higher than the top of the receiver on the trailer - It minimizes the amount of lifting force necessary to level the trailer.
