blown steering damper...
oil everywhere as it happens...
but as you all probably know this is a recall item... at least is is here in the uk... so tomorrow it is being replaced free of charge... [80 pounds sterling...plus vat ...plus fitting...] i'm in ireland by the way... just thought i'd mention it... in case anyone has a leaking unit... !!! |
Wow a leaking unit could prove to be very embarrassing.
Fwiw, once you're out of warranty, you may as well replace it with a HD stabilizer from teraflex. I don't know how their international distribution is set up but it's a very strong unit for nominal cost.
Good luck! |
Originally Posted by RescueGreen#3
(Post 2093877)
Good luck! so i'll get the damper too... cheers ... :thumbsup::beer::thumbsup: |
mine blew.... so i made an appointment. right before i went it for it, i went wheeling, and put a small scratch in the bottom of the shock. that was it for that, void warranty and had to change it myself. now going on my third. it seems you really need a relocation bracket for it if you want to keep the one you have:wink:
Originally Posted by bareass
(Post 2201825)
good info on the relocation bracket... many thanks dude... :thumbsup: |
mine blew at 20k. replaced under warranty.
Originally Posted by dinojeep
(Post 2204223)
Get the Bilstein one. Hands down the best feel.
It's funny. I went thru three new ones from the dealer and they all failed. I finally ended up purchasing a dual set up made by RCS. Have not had any problems since.
