Broken Bracket for the "boot"
Old Sep 19, 2008 | 12:26 PM
Renzo Fighter's Avatar
Default Broken Bracket for the "boot"
Ok, i noticed that my rubbe boot was coming out around the gear shift, so i decided to try and get it back to normal. ok, BAD idea. Now i broke the whole plastic piece that hold it down. I took the top and bottom of this piece out and am now looking for a replacement. Can i get this online? Do i have to go and order it at the dealership? Help! I cant stand looking at the rubber boot by its self!
Old Sep 19, 2008 | 01:51 PM
BaltChief's Avatar
Quadratec has this one and it looks nice....
http://www.quadratec.com/products/52110_900.htm
Old Sep 19, 2008 | 04:16 PM
thanks. i found a OEm one that was like 15 bucks. And its the boot also. Now how do i get the Shifter knob off? Also if i want to change the knob what do i get? Threads are different?
Old Sep 19, 2008 | 04:30 PM
Wicked Wahine's Avatar
There are no threads on the shifter. The knob pulls off..but not easily..the shaft has a notch close to the end ..sort of like a bottle opener...the tip is circular with a flat edge on one side...It is aggrivating to get the knob off but when you do, it can be replaced with the "rock" knob or you can tap it or thread it for after market styles. Mine is a skateboard wheel.
Old Sep 20, 2008 | 12:10 PM
oh you have to thread it?
Old Sep 20, 2008 | 12:28 PM
J2H's Avatar
J2H
How do you thread/tap them, i want a spider shift knob and they come with diff size threads
Old Sep 20, 2008 | 08:32 PM
Alot of after market knobs come with different sized adapters. As far as tapping or threading ..you have to buy specialty tools to do this. Most mechanics have these type of tools..Maybe, if you know someone who works on vehicles, they can do it for you..Mine is McGivered in...seriously I used a sewing thimble and small sheetmetal screws as wedges. The bolt and nut on my photo is a false front but you can't tell......Oh ...I just did
Old Sep 20, 2008 | 09:39 PM
blkpearl's Avatar
check out link below
https://www.jk-forum.com/forums/jk-write-ups-39/shifter-boot-ring-cheap-fix-48498/
i had the same problem and i had to fix the shifter ring, but didn't want to pay the dealer relacement price.....so i drilled and added allenhead bolts
Old Sep 22, 2008 | 08:51 AM
freeswimmingfish's Avatar
I had the same thing happen here too, but I took the top part and painted it silver to match my painted vent rings. Then I glued the top and bottom together with the boot between (not as hard as it sounds). I think it looks great. It has been about a week now and still holding strong. If it comes apart again I will drill it and use screws.
I dont have any pics at this time.
Old Sep 24, 2008 | 03:03 PM
i got one for 15 buck? Now im thinking i got the wrong piece??? I spoke to the guy on the phone and he assured me we were talking bout the same piece. I guess ill see when it gets here?
