Bumper replacement
I own a 2008 4door Rubi and I would like to replace the front bumper. (The end caps are already beaten and dented....PLASTIC you say!) Knowing very little about the mechanics of the bumper assembly I'm having trouble deciding on a replacement and have several questions.
Many replacements come with factory fog light cut outs . Has anyone had issue with the cut out size or mounting brackets on the new bumper .
When bolting the new bumper on and also adding D rings do you interfere with the airbag activation system? (All but one replacement bumper that I've seen do not have crush cans.)
I would like a full size bumper (steel) w/factory fog lite cut outs, D ring brackets and crush bar. Winch platform is not preferred.
Any Favorites??
Thank for your coments
Any Favorites??
Any Favorites??
Any Favorites??
The sensor for the air bags is not in your bumper, so you will have no issues with D rings.
If you didn't say you wanted D rings, I'd suggest the OE Mopar bumper. You could add them, but you need to do some cutting of the crush cans and painting of the affected area.
There are plenty of options. The ARB bumper looks very beefy.
Check out this thread - it has a TON of different designs and they all fit on your JK.
https://www.jk-forum.com/forums/show...PER-comparison
