A/C doesn't blow...
Old Mar 12, 2011 | 09:01 PM
captjay's Avatar
why do you even need a/c?
you live in FLORIDA and drive a JEEP!!
take the top off man!
I couldn't tell you if mine even works or not. never use it because I live in FLORIDA and drive a JEEP
Old Mar 12, 2011 | 09:23 PM
captjay's Avatar
Originally Posted by ECHO
Does you fan work on any setting?? Heat or Air - Might just be a blower resistor.. I would check that first before going to the blower motor. eliminate it one step at a time
while that is great advise to check step by step, typically if it the resistor, the fan is only going to blow in high. but still check it anyways. this could be as simple as that, a relay, a loose connection.
Old Mar 13, 2011 | 06:19 AM
BrowniesJK's Avatar
Pensacola almost doesn't qualify as FL.
I only run with a top and full doors about 20 days a year but 90* and a shirt w/ tie gets HOT!
The dumb thing has started working again so I'm going to let sleeping dogs lie. Lots of mods to pay for
Old Mar 13, 2011 | 08:32 AM
captjay's Avatar
hahahaha nice! yea yea yea ok so what if I live in LA (Lower Alabama) or the bible belt, or thr Redneck Riviera, hahahah. I do wish I did live further South, the top would never go back on.
well, guess if it working for the time being, just roll with it. if you can deal with it, might as well get some other mods done
Old Mar 13, 2011 | 09:23 AM
arnis1968's Avatar
Took the glove box out so I could see the fan. The motor starts to work then peters out quikly.
Old Mar 16, 2011 | 12:08 AM
Otari's Avatar
i had a gf with that prolem, best thing to do is replace it
Old Mar 16, 2011 | 03:40 AM
booberj's Avatar
My blower had stopped working consistently... I replaced the blower motor
52.04 including tax (from stealership) and 10 minutes of my time and it's fixed
Old Mar 16, 2011 | 03:43 AM
BrowniesJK's Avatar
That's cheap.
I'm going to let mine die and do the same.
