a/c issues
So I started my jeep this morning and turn on my a/c it was not cold it was just blowing hot air so I figured I need a re charge but then the jeep purged from the compressor and all the freon hit my front dif. Never had this happen before should I just re charge? Is there air in the lines building to much pressure from a leak? Need some help so please chime in
Originally Posted by kik
Seems like you blew a seal. Re-charging it won't help. What you're most likely seeing is the oil that's part of the system. The freon dissipates.
