Can I program so doors don't auto lock?
Old Oct 3, 2011 | 06:34 PM
19Delta's Avatar
Default Can I program so doors don't auto lock?
I don't like all the doors locking when I go 15 mph. Anyway to un-program this feature?
Thanks! :-)
Old Oct 3, 2011 | 06:50 PM
J-VET's Avatar
Veteran: Marine Corp
Dont want to hyjack but I would love to know how to get all of my doors to unlock with one push of the button on the key fob.
Old Oct 3, 2011 | 06:52 PM
mrlobaloba's Avatar
Both of these functions should be in the manual
2010 JK's Avatar
Hope this helps. got it off the jeep owners site. it is from the owners manual you can downlad for free.
Automatic Unlock Doors On Exit
The doors will unlock automatically on vehicles with
power door locks if:
1. The “Automatic Unlock Doors On Exit” feature is
enabled.
2. The transmission was in gear and the vehicle speed
returned to 0 mph (0 km/h).
3. The transmission shift lever is in NEUTRAL or PARK.
4. The driver door is opened.
5. The doors were not previously unlocked.
6. The vehicle speed is 0 mph (0 km/h).
Automatic Unlock Doors on Exit Programming
The “Automatic Unlock Doors On Exit” feature can be
enabled or disabled as follows:
1. Close all doors and place the key in the ignition.
2. Cycle the ignition switch between LOCK and ON and
then back to LOCK four times ending up in the LOCK
position.
3. Press the power door unlock switch to unlock the
doors.
4. A single chime will indicate the completion of the
programming.
5. Repeat these steps if you want to return this feature to
its previous setting.
32 THINGS TO KNOW BEFORE STARTING YOUR VEHICLE
NOTE: Use the “Automatic Unlock Doors On Exit”
feature in accordance with local laws.
Automatic Door Locks
The doors will lock automatically on vehicles with power
door locks if all of the following conditions are met:
1. The “Automatic Door Locks” feature is enabled.
2. The transmission is in gear.
3. All doors are closed.
4. The throttle is pressed.
5. The vehicle speed is above 15 mph (24 km/h).
6. The doors were not previously locked using the power
door lock switch or Remote Keyless Entry (RKE)
transmitter.
Automatic Door Locks Programming
The “Automatic Door Locks” feature can be enabled or
position.
3. Press the power door LOCK switch to lock the doors.
programming.
NOTE: Use the “Automatic Door Locks” feature in
2
THINGS TO KNOW BEFORE STARTING YOUR VEHICLE 33
Old Oct 3, 2011 | 06:53 PM
RSTRICK's Avatar
I don't think so it is some sort of safer regulation. I don't plan on getting out of mine at 15 plus mph.
Old Oct 4, 2011 | 02:59 AM
19Delta's Avatar
enabled.
position.
doors.
programming.
transmitter.
position.
programming.
2
I this, I can't get a chime at end to complete programming. I tried several times. How long do I keep the key in each position? I tried fast and really slow.
Old Oct 4, 2011 | 06:15 PM
2010 JK's Avatar
I'm not sure. I have not goten around to doing this yet. Here is the link to the Jeep site that I got the manual from. The PDF is pretty big the manual is 500+ pages. I thik it was in page 33 fot the 2010 manual.
http://www.jeep.com/en/owners/manuals/index.html
Old Oct 4, 2011 | 06:57 PM
jimdoss's Avatar
I've tried the above directions about ten times and could never get it to work.
Old Oct 4, 2011 | 07:01 PM
jeep3920's Avatar
Do you guys have any idea if you are able to program the locks like this on an 07? Looked up manuals for 2010 and 2007 and the technique you listed is only in the 2010 manual. My locks won't auto unlock when exiting.... when I put it in park and get out to get something out of the back I have to manually unlock doors and for this you have to push unlock on keyfob several times.
Old Oct 5, 2011 | 06:21 AM
nathanmares's Avatar
https://www.jk-forum.com/forums/show...t=unlock+doors
I think this is what you are looking for. It worked great. So much better than pressing the button 2 times. I always used to forget that and the girl would say I can't get in.
