Check engine light
This is how to pull up the codes:
1. To check your Jeep JK Wrangler’s DTC codes, simply insert your key into the ignition, turn it to the ‘ON’ position but do not start the engine. Then, push the key into the ignition cylinder and while holding it in, turn it to the ‘OFF’ position and then back to the ‘ON’ position (3) times straight making sure to end with it in the ‘ON’ position. It is important to keep pushing in on the key to prevent it from catching at the different positions along the way.
2. If you do step #1 correctly, all your dash lights will illuminate and your odometer will show up as a series of (6) dashes. If your Jeep JK Wrangler has logged any DTC’s, they will be displayed soon after the dashes appear. Write down the DTC(s).
3. If your Jeep JK Wrangler has not logged any DTC’s, the dashes on your odometer will be followed by the message ‘-done-’. Turn your key to the ‘OFF’ position and you will in fact be done.
How does it feel to drive? Making any noises out of the ordinary or sputtering or running rough? That web site I posted gives a list of symptoms and possible solutions. If you aren't getting any of those things try going to Autozone, they have OBD-II readers and will usually turn off the codes for free. Hope you get it figured out.
I just checked it again and although the check engine light is still on all I get is dashes and then 'DONE'...the code won't come up anymore.
Ideas? I wish I wrote the damm thing down the first time.
Well now this has me all confused the check engine light is off & no code is up, the only thing I did was make sure the cables were on the plug for #6 cylinder drove home from work the dam check engine light went off!
I would like to thank everyone for the help
- When Monitored: Any time the engine is running, and the adaptive numerator has been successfully updated.
- Set Condition: The threshold to set the fault is application specific; it is tied to the level of misfire that will cause emissions to increase to 1.5 times the standard or in some cases 1%. It is always a two trip fault above the calibrated RPM. It takes 1 soft fail to set a malfunction and two trips to set the MIL. Three good trips to turn off the MIL.
I come up with 19 codes in the P04XX series.
P0401 - Egr System Performance
P0403 - Egr Solenoid Circuit
P0404 - Egr Position Sensor Rationality Open
P0405 - Egr Position Sensor Circuit Low
P0406 - Egr Position Sensor Circuit High
P0420 - Catalyst Efficiency (bank 1)
P0430 - Catalyst Efficiency (bank 2)
P0440 - General Evap System Failure
P0441 - Evap Purge System Performance
P0443 - Evap Purge Solenoid Circuit
P0452 - Evap Pressure Switch Stuck Closed
P0455 - Evap Purge System Large Leak
P0456 - Evap Purge System Small Leak
P0457 - Loose Fuel Cap
P0461 - Fuel Level Sensor 1 Performance
P0462 - Fuel Level Sensor 1 Circuit Low
P0463 - Fuel Level Sensor 1 Circuit High
P0480 - Cooling Fan 1 Control Circuit
P0481 - Cooling Fan 2 Control Circuit
My 08 started showing me the check engine light. I have an OBDII code reader and it gave me this code P0420 code. I looked it up and it has something to do with the catalyst System. Anybody else having this same error code?
